I moved from a Futaba 14MZ to an X9D+ and was amazed at how much you could do with OpenTX. Being a radio geek, I bought the 2019 version as soon as it came out, and then I picked up the new X20S when they came out. I think I am pretty competent with OpenTX and had no problems programming anything I needed. When I first sat down with my X20 and played with the programming on it, I found it similar to OpenTX in functionality but easier to work with. Mind you Ethos isn't done yet, but they are adding features rapidly and responding well when people point out some of the rough edges. I wouldn't go back to OpenTX.
Everyone has to decide what their budge is, but my suggestion to newcomers would this. If you don't know if you are going to stick with the hobby and just start off super cheap, go with the X9 Lite S, the radio signal is as good as the more expensive radios and the lower price comes at the expense of some switches. If you have flown before and are getting back into it and thus think you have a better chance of staying, I would go with either one of the higher end OpenTx versions, like the X9D+ or whatever, or, if you can afford the extra money, get the X20. I wouldn't recommend the X20S, I bought one due to peer pressure from my buddy, but I am sure the X20 would have been just as dandy.
One thing to note is that programming on either OpenTX or Ethos is vastly different than your old radio, but once you get a basic understanding of it, I think you will really like it.
I also suggest downloading OpenTX Companion which is a program for you computer that allows you to edit and test your setups. On it, you can play with and start to understand the OpenTX philosophy, which is applicable to both OpenTx and Ethos. You can download the latest companion from here:
https://www.open-tx.org/downloads (follow the link there to the newest version).
