On-board configuration: dual ACCST RX8R-PRO's or dual ARCHER R10-PRO's
Hello all. Looking from some suggestions here.
I'm starting with a quarter scale Decathlon with 35 cc gas power. My Tx is an Ethos-ISRM-Horus X10.
I want to use redundant recievers, so Im considering dual RX8R-PRO's or dual ARCHER R10-PRO's. So my question is this: since I'm going to need 10 Channels (2 ailerons, 2 flaps, 2 elevators, 1 Rudder, 1 throtthe, 1 kill switch, 1 smoke or lights), in case I decide to use the RX8's i'm going to need SBUS expansion for those 2 extra channels. So, If Master RX8 uses Sbus-in, and Slave RX8 uses Sbus-out for the reduntancy configuration, can I daisy chain the 2 additional servos into the Master's Sbus-in? Or should I forget about it and go with the 2 redundant R10's to avoid the Sbus expansion?
I'm considering the R10's for additional battery redundancy...., and use ACCESS protocol rather than ACCST....
If I go with the R10's, should both batteries go to the Master Rx, or makes sense to have one in the Master and one in the Slave? I the battery in the Master dies, would the battery in the slave still be able to power things up: Master Rx up, Master battery dead, slave Rx standing by, slave battery powering things. Makes sense or I'm trying to make the wheel rounder?
Please give me your thoughts...
Thanks a lot in advance and nice flights and better landings for everyone!
  1. I would stay with the PRO versions due to the gas motor. The Pros have additional filtering to fight ignition noise.
  2. It sounds like the ARCHER R10-PRO fits your application better.
  3. The secondary receiver does not need to have all 10 channels. All FrSky receivers output all of the channels when used as a redundancy unit.
Hope this helps.
Thanks for your feedback, Wayne. You just told me something I didn't know... the slave Rx doesn't need to be also a 10 channel... so, In theory, It could be any Archer reciever, even an M+ or an R4? My only constraint for the slave would be a PRO version reciever....
So I guess my master will be an Archer R10-PRO, my slave an R8-PRO and the redundant batteries will be handled by the R10.
Many people have become used to some other receiver manufactures where an 8 channel receiver is only 8 channels. When using S-Bus with FRsky receivers you get all the channels. So the 4, 6, 8, 10 etc means PWA outputs only. You will need to be running ACCESS on both receivers.
I'm still chasing my tail here. There are so many options, I'm not sure which is the best. So, my question is, being a relatively big model with 7 relatively hungry servos, is the R10-PRO good for such an application? I mean, what is the max consumption it can handle?
My alternate option would be to use an RB25 and two R8-PROs via S-Bus. As said above, the R8Pro is able handle 10 channels this way right?
I feel comfortable with all the big consumption going through the RB25 rather than through the Rx. Is this an overkill?
Enviado desde mi SM-G9600 mediante Tapatalk
