This is a new Archer GR6 with the variometer and altimeter telemetry. It's been updated to the latest firmware (but I had to use the S.Port as OTA upgrade would not work) and works fine as far as the receiver goes with good range and no control problems. The problem is the telemetry is really sketchy. I've set it up per the manual as far as I can tell. The altimeter works but it's erratic and inaccurate. I'll see it a '0' on the telemetry display on the ground and when I first launch. I'll also see the aircraft's altitude displayed and changing as I climb and descend. When I finally land and look at my altimeter display in the TX it's no longer '0' but some seemingly random altitude, not '0'. Makes me think that it's not giving me accurate altitude readings. The variometer does not work at all. I never see (or hear from the audio) a change in ascent or descent rate, even when the plane is under power and climbing rapidly.
Am I missing something in the setup or do I have a defective receiver I need to send back to Aloft?
TX is Taranis X9D Plus (2019) with latest firmware.
