Obelix Build Log
Dunno! Oh wait - that’s very interesting- I just dug out my 1983 copy of Silent Flight and it says right there that the section shown on the plans are good for strong conditions but a flat bottomed section can be substituted for lighter air, and yet the plans only show a flat bottomed section. The inconsistency is in the original publication!
Anyhow, back to the Obelix - finished making the templates. After rough cutting the templates on the band saw, I sanded them to the final shape. The convex upper surface contour is easy enough on the disk sander, but the concave curve of the bottom surface templates required the sanding drum.
To clean up any slight waviness I made a semi-flexible sanding stick out of scrap Formica. The idea is to be flexible enough to bend to the concave curve of the airfoil, but stiff enough to bridge the unwanted smaller period waves. I’m eyeballing it here, the occasional unwanted waviness is no more than 0.01” or less. The sandpaper does not extend to the ends of the sanding stick so that the sanding stick can slide along the template without introducing uncontrolled sanding from the ends - if that makes sense…
And maybe that the person that uploaded just couldn't find the original plans?
The "club" (Ivinghoe Soaring Association) one we used came from the designer and was a simple A-4. I didn't know Silentflight had published them.
Ah, that makes sense of course. Do you recall if a semi-symetrical section was presented on your club plans?
Yes, as I remember it was an Eppler E374. And I think a symmetrical NACA 009 at the tips both at zero incidence. Pretty aerobatic with those sections.
Been busy with the lead up to last weekend’s Mill Valley Fall Arts Festival. Today I finally got around to cutting the center section. The 22” chord was a stretch for the cutting bow’s swing arm but it did it. A straight forward cut but I still managed to get a couple of skips in the wire. No biggie, the little ridges will sand right out and I doubt this sport foil will care.
Thanks Doc!
Decision time - in the interest of simplicity, I’m going with a one-piece wing. Wing servo wires need to be routed to the fuse pod. I can get a straight shot from the fuse pod cutout to an acceptable servo pocket location with a long 1/4” bit. Holding the drill on a sliding sled keeps the bit on course.
The wire channels popped out on the upper surface of each outboard panel within 1/8”-1/4” of each other - good enough. A circular servo pocket will overlap/mask the exit hole locations
is that a tape measure attached to that screw gun?
Hah - good eye! The bit is so long that the drill tips forward when I’m not holding it down so I placed the tape measure on the back so the drill bit would remain parallel to the work bench while I took the photo. In the second photo I’m using a scrap of wood under the chuck.
Adding a bridging spar to the top surface to tie the outer panels to the center panel to help in tension (negative G) since the wing skins on the top are mostly segmented by the discontinuity across the panels unlike the bottom skin which continuous/unbroken span-wise.
Bottom sheeting - fingers crossed. The Obelix planform was not conducive to bagging since my bags are only 15” wide and the center chord is over 22” and I’m sheeting the bottom in one contiguous piece. I have 3/4” ply on top of the shuck/core/shuck stack plus a bunch of weight piled on top of the ply.
Also the sheer volume of things to try and weigh that down is the best advertisement for vacuum bagging IMHO. The space savings vs a pump has been great.
Yeah epoxy. It was a trade off. Sheet the 3 panels separately and vacuum bag them, or glue the 3 panels together and sheet as one piece clamping down with weights
I got rid of all my old AMA mags, probably 75 pounds worth, otherwise they would have made great stacking weights
