I like the design of the servo pocket locations in the wing. Good design. No, that is a great design! Thank you for putting thought to the space limitations, this is an area we see some designers forget to give the proper attention to. This is a nice advantage of the sinewave spar giving critical space for the servo tray. (I might suggest a little bigger pocket, looks a little small in the drawing..? I'm probably wrong.
I don't know how thick the wing is at the aileron, but if it is getting really tight, consider flaring the wing in the servo box area. This is something they did with the Prodij with great results, very skinny wing, but could still fit a fatter servo. That Prodij was probably the best 60" plane ever made. Maybe not pretty or well finished, but it had a very wide performance range for a 60" plane. Here are some pics that sort of show the bumped area for the ailerons. Both top and bottom bump out a couple of mm.
Timing is good, I was just paid for this last Prodij, she ships out today. The last great example of a great performing model.
Great plane!
PRODIJ is an example of model that was designed and built to perform, and was made with the latest technology of the time.
I'm sure the design is at least 20 years old.
It was not conceived to look good and sexy - although I find it so; rather it completely disregarded fashion and everything about it was put there to wring the best possible performance out of a 60" wing - which it did/does really well.
I think the Prodij uses Marcel Guwang sections, maybe MG5. I had a lot of conversation with Marcel over this many years ago when I ws beginning to develop my own wing sections. For info this is also a reflex type section and it works very well. Not so aerobatic, but adequate and screaming fast.
OK, Back to the Toccata:
Having given this new model possibly more thought than I have ever invested in a model aircraft design, I have made the servo bays in the new Typhoon Toccata at 45mm x 45mm in an 8% thick wing. At the point I put them, the wing can actually take 10mm thick servos with no problem at all, so no need to "bulge" the wing - though that's one way of doing it.
Reasoning:
- Given the high torque performance of the latest servos available, they no longer need to be placed in the mechanical centre of the control surfaces, and the small size makes them fit into a much smaller servo bay. Basically they are well strong enough to do the job.
- Added to that, stiffness wise, the trailing edges in my models are all carbon reinforced to prevent twisting as far as possible, so the load transmission gets much better.
- Logically its always best to put the servo bays a far inboard as possible for reasons of lowering the MOI, but we also have to keep them out of the way of the cluster of wing joiner and ballast boxes at the wing roots.
- Last: In the inboard area its always easier to compensate for the stress raiser that the servo openings actually generate too.
So, 10mm servos are OK, obviously 8mm are OK and there are now a lot of both, so no problems.
6mm wing servos?
While we are on the subject, right now I have two sets (8) of 6mm thick wing servos from Kingmax which I can tell you all have been thoroughly tested - and they are really great.
Therefore, I am completely sure the MKS and KST and maybe other servo makers also have this kind of servo under develpment.
Plug for Kingmax:
Kingmax servos are rapidly gaining share in the GPS Triangle market as the servo of choice, and I'm sure those GPST guys know what they are doing with their ultra-expensive models.
I know Kingmax has received a bit of a bad rep, probably justifiably so in the beginning, but time passes and knowledge accumulates. Jeeze, I remember the time years ago when if I saw "Made in Japan" I'd hesitate to buy the product. I'm not sure about all the Kingmax products, but right now the 100, 8mm and new 6mm servos are close to, if not on a par with KST.
The future:
With these servo developments - which no doubt will continue - in mind, I hope I have designed for posterity as in the future I think bulging wings and huge servo bays will no longer be needed - or at least I hope so!
