dean mcinnis
Guys:
A few questions - as mentioned earlier, I fly helicopters using the throttle and collective manually so I typically place 2 sliders (without detents) close to each other.
Can I purchase some more sliders / sensors from you? I also typically build TX's with a set on both sides of the transmitter so right-handed people can use my TX as well (with a toggle switch between the two).
I would also like to purchase some extra connectors to connect the stick to the mother board and connect the sliders to the mother board (as I hope to have 4 sliders without detents if possible).
Would you know if a stick from an older TX (Kraft or Futaba) will work just as well? I understand the gimbal and pots would need to be used (probably) from the older TX's
I haven't started this build yet, waiting to see if I can get more parts (note: I would purchase the antenna wire as well from a previous post just in case I run into an issue there too
. Thank you! Dean
