GardenGate
User
@Wayne and/or @RafaelAvila - if you have any of the kits left, I would be interested - I have an X10S to work from. Alternatively, I would be willing to buy the STL files to do the 3D printed parts myself.
Please don't hesitate to reach me out if you have any questions.I've been flying single stick for 45+ years and to add to the fun, I'm left-handed and I fly helicopters with manual controls for both throttle and collective (they are not electronically mixed like almost everyone else). This means I have to have 2 pots about a finger width apart on the top-left side of the box (similar to Konrad's photo just on the left side). I've had a few TX's built over the years and have been lately putting throttle and collective pots on both sides of my TX with a toggle switch on the top so I can let other right-handed people use my TX to fly my craft if they like. I typically try and put the stick in the middle of the box if possible for more hand rest room and keep most of the switches on the top of the box just to get them out of the way.
I just ordered one of your kits (waiting for it to be shipped). I'll send some photos of the final version! me
This is a really, really nice kit.
Almost all of X10S's controls, buttons, trim tabs, the vibrator, and the rubber cover for the usb port find their way to this 3D-printed box. All but the left stick and 2 of the 4 switches on the left side, replaced with the 3rd-axis stick with a button on its head, and the throttle slider.
I have some problems:
1. The wire to the external antenna is just too short to reach the top of the box. Where can I get that antenna connector, with a slightly longer wire to reach the top of the box?
2. While I am not using an external module with this radio, the 5 pins to the external module are too long for the back board to close. I will have to cut a hole in the back board to let the pins poke through.
3. I found the battery holder broken in the bag. I glued it back to get the build going, but I don't know how well it will hold up. I'd like to have a new battery holder if possible.
4. What's the tab with 2 holes on the battery holder for?
5. I ran out screws in the bag. The screws are only enough for the box itself, but the throttle slider, the battery holder, and the gimbal all need screws, too.
I still need to solder on the wires to the new controls...
R: don't worry about it, its just my notes for the bags, you need to use your throttle sensorHi Rafeal - just got my kit last night - thanks for the quick shipping, and really looking forward to putting this together!
A few questions to start as I look at the contents and the online instruction manual:
- there was a PostIt note in my plastic bag with "NO SENSOR" written on it - what does that mean?
- are the laser cut plywood plates purely aesthetic or are they necessary or useful from a structural point of view? I'm trying to decide how I want to the radio to look - whether to retain the wood finish or try to wrap the radio with vinyl (e.g. faux carbon fiber). If I wrap the radio, I'm trying to figure out whether I need the plywood (and/or could remove the wrap and screw the wood facing on at a later date) I can see that perhaps without the plywood, the wrap might show through the surface imperfections of the 3D printed parts - I'll have to see how that goes.
R: yes sorry the manual is a little bit wrong, you can use contact glue in all the wood panels that is what i recommend.
- related to the plywood plates - I noted the instructions say that gluing the wood faces to the 3D printed parts is optional - I see that the sides, top, bottom and back would be held in place with the screws, but there aren't screws for the front, so that needs to be glued, no?
R: just no were to put it and keep it aesthetic pretty, so this two is left behind saved inside the radio, you can use it if you wanna just find the place you wanna it and drill the hole.
- is there a specific reason two switches are left internal? I haven't looked closely enough at the final physical layout, but would there be room either on the top or front of the case to drill a couple more holes to have external access to all the switches?
R: just ready the instructions that should me pretty straight forward with the build process, if anything comes up, don't hesitate to message me here.
- any hints or things to watch out for that folks might mention as I disassemble my donor X10S Express?
Cheers!
Bill
Are there enough pins on the circuit board for all the existing switches plus the new button on the stick head?is there a specific reason two switches are left internal?
So I can connect the 3rd axis stick to one of the ports for the left gimbals, but for the new throttle slider have to take over from one of the analog sliders or knobs?R: don't worry about it, its just my notes for the bags, you need to use your throttle sensor
that's exactly what you need to doSo I can connect the 3rd axis stick to one of the ports for the left gimbals, but for the new throttle slider have to take over from one of the analog sliders or knobs?
(I just placed the order for the RF cable. Thank you!)
