Need motor recommendation
Flyguide
Hi I have added the Triple neo thermic to my cart, but I need a motor recommendation (one with easy install with wires in the back. At this point I plan on flying as a thermal ship.
Have you seen the build video by Bavarian RC? Very helpful. I built the 2m res version.
Here is what you need:
Motor: https://alofthobbies.com/products/emax-gt2218-1100kv?_pos=1&_psq=1100kv&_ss=e&_v=1.0
ESC: 30A
Prop: https://alofthobbies.com/products/aeronaut-cam-10x7-25-5x18-cm?_pos=8&_sid=d0f7a6567&_ss=r
Spinner: https://alofthobbies.com/products/turbo-z-folding-prop-spinner-32mm?_pos=1&_sid=2dce374a4&_ss=r
Collet: https://alofthobbies.com/products/turbo-folding-prop-spinner-collet-4mm?_pos=1&_sid=3f1673b2f&_ss=r
The Triple Neo will come with a 30mm spinner assembly, but no collet, since they don't know what motor the builder will use and what the shaft size will be. Don't bother with it. The setup I am recommending will require the nose to be cut/sanded slightly further back to allow enough shaft to stick out for the fancy 32mm all metal spinner assembly you'll be using to grab onto for mounting.
Page 4 and 5 of the build manual goes over cutting the nose and installing the stock spinner assembly.
https://aero-naut.de/downloads/en/anleitungen/1128-xx-Triple_NEO_instruction_en.pdf
