I am running SR10 Pro as master and R9 SX as slave and when I did a range check I lost signal on the R9 SX receiver first. What could I be doing wrong?
All so what does 10mw mean. Your help much appreciated--thanks.
Increasing power usually increase range and the potential for RF interference. What radio are you using and where are you located? A lot of the power restrictions are dependent on the legal limits allowed in your country.
With this SR10 Pro (using stabilization) and an R9 SX, can I add channels to the SR10 with 2 SBUS extenders (4 at a time)? Does the R9 just deliver a signal to the SR10 that then drives the PWM outs? (’scuse my ignorance)
Tks Wayne. How about the sbus channel extenders (x2) - will they work ok? And, supplementary, does the stabilization on the SR10PRO still work ok when the signal is coming from the R9?
Assuming this is good, which 900 module and Rx will I need for my Horus X10S Express pls?
