S
stepheneadams
Guest
Basic redundant RX scenario to this point has been a PRO plus second RX connected via SBUS. So...
Stephen
FrSky X20 and X10s Express
- Can a TD RX link with a PRO for redundancy? (In this case, on the 2.4 band only) Does Tandem RX and Archer Access play ball together?
- Is this accomplished by reassigning output channels at each RX?
- RX One: Ail-1, Ele-1, Thr, Rud, ...
- RX Two: Ail-2, Ele-2, Flap-1, Flap-2, ...
- Must these RXs be connected by SBUS; or is it driven at the Bind level
- Based on the above, I assume stabilized outputs be attached to any of the multiple RXs? Meaning only one (1) RX is S-series is required?
Stephen
