I suffered a laps of judgment at the last F3F race at the slot. Well, my Sanda Mach 2 suffered!
I got caught out with no lift. I was forced to make a way off field landing. From 300 meter above and about 1 Km out the landing looked good. It wasn’t until I got to the landing site that I see I had found the only place on the valley covered in rocks the size of my head. Really this was the only place, the rest of the area was tall prairie grass.
It was asked of me how would one repair such damage? I will try to document my repair of these wings. Unlike the spar damage we saw with this 60” racer, most of the damage is limited to the Leading Edge (LE) of the wings.
forum.alofthobbies.com
The first thing one needs to do is relieve the stresses on the wing. Unfortunately I did a lot of this on the slope, before taking any photos. The top part of the first 2 cm of the LE at the impact point had curled under. This was distorting a lot of the wing LE. So I uncurled this area as soon as possible at the slope.
The next step is to relieve as much stress in the foam skin as possible. This means often picking at the crushed area trying to get as many of the fractures to realign. Once you have the wing looking like wing ( no stones, straw or loose pieces of foam and epoxy distorting the wing) I then heat the area with an iron set at about 85°C to 90°C. I like to use a wet paper towel to help with the heat transfer and to make sure that I don’t over heat the area. This heating relieves a lot of stress in the epoxy and fibers of the skin.
Next I try to stabilize the foam skin with CA. Do make sure that the parts and fibers are aligned as you don’t want to glue the parts out of alignment. Note; this CA is not to try to glue the wing together. CA is a weak glue. For strength we will be using epoxy and fibers to regain any of the lost strength.
The photos are trying to show the damage to the LE. This damage should be rather straight forward and well within the capabilities for most modelers to repair, other than the paint job. Now what does concern me is that the flap horn area is showing a lot of deformation. This means that the flap took some loads as the wings shifted on the fuselage. I landed clean with no flaps.
Skin repair of molded models (60" glass and rohacell racer)
It pains me to admit this in front of everyone, but I damaged my little 60" moldie racer. The good news is I don't think I damaged the main spar. You can see that the wing skins are showing damage. At the flap hinge line both the upper and lower skins are showing tension damage. A head of the...
