j ferguson
User
It looks like this is possible. If someone will confirm that it is possible, I will dive in and figure out how to do it.
The issue is that I can't judge airspeed when I lower the flaps and of course get a big nose-up which I can handle ok. But it is unsightly. When one is inside the plane this isn;'t an issue because you know the airspeed and without thinking about it can push the wheel forward as much as needed and re-trim.
I thought I could tie the amount of down elevator needed by assuming airspeed might have some connection with throttle setting and accordingly I could apply whatamounts to trim to the elevator as a function of throttle setting and flap angle.
If this seems crazy to you, it's ok to say so.
Taranis X9D
john
Taranis X9D
john
