Thanks; so the FW runs through the menu from the top down. I'll take out one SW entry and see what happens.
This is what I usually do, but if you have an aggressively aerobatic plane you may want that "default" setting to be tamed down some. (This plane can fly on full rates just fine.)
Are you telling me that the FW won't execute the default setting unless something else in the chain goes missing?
CR
But if that's true, the lower 50% switch position would have been eliminated..Not what's wanted.The firmware scans top down (In each input or channel) for the first line that has a "true" switch position and executes that line ignoring those below. If no lines have a true switch position then the that channel is inactive. Having no switch value leaves a line true all of the time. So, if the bottom line without a switch position is "true" all of the time - if the lines above don't have true switch values then the bottom line is the first line that's true.
In the example Wayne showed above -- he COULD have actually removed the bottom line with 100% and the switch position from the second to the bottom line to accomplish the same result saving a teeny tiny amount of memory.
CR
