I think the average seems to be about 22mm for the CG and 2 to 2.5mm of reflex upward on the elevons. The elevator throws should only be about 3 to 4mm up and the same amount down, more will only get you into trouble. Some will want less, a few may want more. The CG will alter how much elevator input can be tolerated. For the roll, you can have a ton if you like. but I would suggest starting on the docile side, maybe 5mm up and 5mm down, tune from there. (Throws are measured at the trailing edge.)
The plane has shown it can fly well in light lift conditions, but best for the maiden to be in a moderate lift day. If the lift is bumpy, the maiden may be a little more difficult.
Planks are always a challenge on their first flights. The CG is a very small range, and the CG will alter how the elevator works. Typically as you push the CG back you will usually reduce the elevator throws. Push the CG to far back and it will not be fun, and too far forward and you will not be able to keep the nose up, or if it flies you will be up and down all over the place. It can feel like tail heavy, but is actually nose heavy. And tail heavy is just like tail heavy.. At least this is my experience. But get that CG just right and you will have a very efficient plane that loves to carve turns and holds energy really well.
A "Plank" flying wing is a different animal than a "Chevron" flying wing. The simple way to describe them is a Chevron will have a lot of wing sweep (forward or reverse). Like this early Northrop:
These Chevron's have a wide CG range and can have large throws on the elevator. They are rather forgiving, I once lost my balance lead on one and could still fly even though I lost a substantial amount of nose weight.
The Mini-Q does not have all of that wing sweep:
This is a PLANK design and the CG range is very small, and the elevator throws will also be very small. They are not tolerant of the CG being off. Either they fly or they are not flyable. You will see very few aircraft with this design for carrying a human as they simply are to critical. I have seen some try though.. So why mess with a plank when a Chevron is easier? In my experience they just flat out are much more efficient. I'll let an aerodynamics major speak more precisely on the subject, but they present less drag.
I hope this helps some.. I'm sure someone will find fault with something I said.. but that should be pretty close.
