One of the benefits (or curses) of having Aloft Hobbies as my local hobby shop is that I get to go through customer returns. I went in to Aloft Hobbies looking for a 60” racer other than a Sunbird and walked out with a customer returned Sanda Mini Mach. I’m still in need of a good value 60” racer for “Man on Man” racing.
alofthobbies.com
This customer return was for a damaged wing. The damage is so difficult to find that the customer didn’t find it until well into the assembly process. This wing is showing delamination for approximately 1/3 the span on the starboard wing.
By the way this is why it is so nice to deal with Wayne at Aloft Hobbies. He is also a real modeler and fully understands how damage ( shipping or manufacturing) might not be found until well into the assembly process. (Just try to explain to some other importer that damage was present before you started assembly. All you are like to get from them is motion sickness from all the run around)
I don’t think this delamination is a manufacturing issue as the epoxy bead leading edge is broken into three pieces. I looked for signs of an impact point and couldn’t find one. I suspect that the wing was subjected to a shock load directly on the leading edge And it is this shock that broke the LE and delaminated the top wing skin. I don’t think this delamination has anything to do with the manufacturing of the wing (dry layup).
To repair this damage I’ll need to inject a very low viscosity epoxy under the delamination. I will have to rely on capillary action to ensure that the epoxy fills all the voids under the skin. Time will tell if I got a killer deal on this model or if I payed top dollar for scrap carbon and foam!
Mini Mach Sport Glider Carbon Version
A nice and stiff carbon composite glider from Sanda Models.
