He flies!
For very small values of flying. That is the backyard of a San Francisco victorian! I tossed the micro Sinbad in the backyard and near by baseball diamond.
I had to go with an external XJT module to get that dated VD5M to work with my Taranis X9D 2019 tx. But all appears to be good.
I was looking over the Sinbad and crying how tail heavy he is. CG is 45mm aft of the LE. Then I recalled that an airfoil knows nothing of CG it is the airframe. Seeing how large (oversized) the stab is. I was thinking heck many free flight glider of the same time era (40'S) had the cg as far back as 85% with their huge stabs!
So I talked myself into thinking it will fly with the CG at 45mm. I set my rates at 65% with an expo of 55 and tossed him into the wild blue yonder. Well much to my surprise he flew fine and responded the controls rather well. From shoulder height I didn't see any divergent flight. Back home I went, and drilled another hole in the servo arm at about 4mm. I had to do some monkey business to get the push rod to clear the servo output shaft. But I'm happy with the geometry. I set the dual rate for 100% 80% and 65% keeping the expo at 55 for the two larger values and dropped the expo to 45 for the low rate. A flight from shoulder height the elevator is a bit sluggish at 65% with the 4mm servo arm . But 80% is starting to feel ok.
Again these aren't even test flights rather test throws in between rain showers.
Now I'm really wanting to get him on the wing and see if he tucks at speed with the CG at 45mm!
Please note the windshield glare!
