As you might know I don't subscribe to the notion that if it looks right it will fly right. That might fly for an artistic designer but as a design engineer that's a no go!
My creed is form FOLLOWS function not the other way around. To that end system integration is key to a good flying model.
With this micro Sinbad I've deviated from the designer's intended radio system. This design was drawn to use a "brick" with 2 linear servo. I've chosen to use 2 rotary
2.2 gram servos and a discreet RX. As a result I've had to make major changes to the servo mounting and push rod routing. While these are my changes, I think much of this can be applied to the as designed configuration. Key to all this is servo resolution. If you need to cut down on the servo motion in the radio to less than 80% it is time to reassess the linkage geometry.
To start the radio installation I set my servo arm to be as short as I think practical. I have to clear the servo output shaft. Here I've drilled a 0.026" hole in my servo arm at 5.5mm. (The OEM servo arm holes are 0.04" which are way too large for a micro)
Next is to choose a control horn that is long enough to allow the anticipated motion. Here I'm using a 6.5mm rudder horn and an 11.5mm elevator horn. These horn lengths will dictate where the push rod exits will be.
I use the push rod cross over method to try to get as straight a push rod run as practical. Since this means the push rods will cross they need to be on different planes (geometric term) so as to not rub. (Rubbing causes cross talk and centering problems) Make sure the push rods run free. This is why my rudder pushrod is above the servo arm as it exits the fuselage above the elevator push rod. (This is a function of the control horn length).
I think the plans call out 0.020 music wire as the push rods. I find these too flexible for my liking without the use of a Bowden tube. So I'm using 1mm carbon push rods for the added stiffness, control response. I use 0.025 music wire to make my "Z" bent ends. To attach these Z ends to the carbon push rod I use small heat shrink tubing. This affords me the needed adjustment if needed as I can slide the ends along the push rod. Once the plane is in trim I can lock the Z bend onto the push rod with a small drop of thin CA glue.
Now making this type of push rod is dangerous in that the heat to shrink the tubing can damage the iron on covering. I find that some aluminum foil makes a great heat shield. Just make sure there aren't any large holes to allow heat to burn the covering when applying the heat gun.
