Well, the effort to loose some tail weight was not only fun but productive. As shown the laminated outline with open structure is 38% lighter than the as cut sheet vertical fin.
I also maintain that the new structure is much stronger and more resistant to warpage. As a former material and manufacturing engineer it is incumbent that one use the advantages and limitation of the materials to the fullest. Key here is to use the wood grain to define the shape and resist warpage. The downside is that the OEM would have to provide basswood strips (actually 1/32 contest grade balsa would work and would be lighter still). The manual would have to describe the laminating process.
Ok, the 38% callout is a bit optimistic as both fins will need covering. This will lower the percentage spread. But the 0.45g loss would still be valid. This will translate into another 1.5 grams of saving from the loss of nose weight. For a total weight loss of close to 2 grams! This kind of weight improvement will be even greater with a restructured stab!
