I am having similar issue:
I also have a gasser with a two RX8R-Pros connected to a RB-20. But between the RX8R-Pros and RB-20 I have a CORTEX Gyro with redundant serial inputs and outputs. After 5 flights, I got RBS=80 several times. Two flights had no RBS issues but 3 had 3 to 5 ocurrences of RBS=80. The telemetry was also logged at 0.5 s intervals. 80 means "RX1 Physical Connection Lost" and "RX1 Signal Lost" I was suspecting a wiring issue, but redid my wiring for this flight.
In my case, I am not sure if this could be caused by the Cortex PRO.!?
I have bound RX1 as CH1-8 TELEMETRY ON and RX2 CH9-16 TELEMETRY ON.
I tried to match RBS errors with current draw amps and RX voltage on telemetry and found nothing suspicious.. Voltage has always been good. So does RSSI. always above 50%.
I do have other 2 XM+ connected at the RX8R-PRO SBUS IN as a backup RX. So in total my setup has 4 RX's
I will try and swap RX's in the RB20 and see if I bet the same error but for RX2. This should confirm if the error is on the RBS or before it.
Not too long ago I moved my fleet completely from Spectrum to FrSky. All my planes are FrSky and I really like their products. But they could care less for their customers.... I am never able to get support from knowledgeable people...
Let me know if you have any progress on your troubleshooting. I am really interested in the outcome.
Thanks.
