Step 8. Position and glue the servo frame in the servo well.
Insert the ball bearing into the servo frame and CA it into place, because there is no access to the bearing once the servo tray has been glued into place. Take great care not to get CA into the bearing itself! Attach the servo horn to the arm using the supplied 1mm hinge pin, then insert the horn into the bearing. Finally mount the servo, and mark the correct position of the servo frame on the well floor.
Disassemble and glue the servo frame using an epoxy and filler mixture like before. In my case the top of the servo frame touched the other wing skin (on the servo cover side) so I was able to glue that as well, making it a very strong assembly.
Once the glue has cured, assemble everything again, and test the servo travel with a servo tester or your radio.
On the ailerons the wing was so thin and the clearances so tight that I had to cut notches in the servo frames to clear the pushrod arms, see below:
Finished flap in the up position:
Finished flap in the down position:
I get a full 90 degrees of down travel, and still have sufficient up travel to mix ailerons into the flaps.
Is there an easy way to upload videos? I would like to show the flap and aileron travel.
