I am glad you find my manuals useful. The first one for X9D+ took 15 months of all my spare time to write. The X7 variant took another 4, then the X10 another 5. The maintenance has tapered off a bit, until the next big release.
Your comments about thrust make sense, so I will add 2 + 2 deg. I will use an aluminium bar held against the front opening to set these. The diameter of the opening is 36mm, so for down thrust I need to file a channel SIN(2*PI()/180)*36 = 1.3mm deep. The bar is 10mm wide, so for side thrust I need to file an angle of SIN(2*PI()/180)*10 = 0.3mm.
