I've see that, definitely fairly quick! What motor/prop setup are you using?I believe my setup is in that power range. Haven't clocked it for speed yet though. Have a look at my video in this thread.
It's a rather old Aveox F27 F5B with a 3.7:1 planetary. it's on 6S spinning an Aeronaut 15x13 prop.I've see that, definitely fairly quick! What motor/prop setup are you using?
We can order them for you, just drop us an email: contact@alofthobbies.com and we will get you going.looking for an extra wing joiner/wing rod for a Magnus or a place to order one- thanks
The epoxy has already failed, Justin. More won't help.Is this a common occurrence for carbon planes? This happened on a gentle landing on a soft grassy soccer field.
View attachment 21945Suggestions for repair? Just epoxy the hell out it?
Thought about that. I epoxied the tail on though, and I'm worried that if I dig and grind it all out, the seat for the tail will no longer be true. There are a couple of spots on the non-damaged side of the elevator that I see the white epoxy missing from the TE, so this one may have been made with a poor mix? Just grabbed a bottle of extra thick Smith CA, so will give that a go. Worse comes to worse I'll cut it off and make a balsa replacement.Not normal at all. Would you like a new replacement part? Go ahead and repair that one for now, but we can order up a replacement ASAP.
My original thought was to fill the void between the old epoxy with the same epoxy I used on the control horns, then a bead of thin CA along the TE. We'll see how much of a mess I make with it.Not normal at all. Would you like a new replacement part? Go ahead and repair that one for now, but we can order up a replacement ASAP.
For repairs I would suggest using a structural epoxy. CA will offer greatly reduced glue strength in this application. Sourcing a thin structural adhesive can be a little tricky though, not going to find it locally. Sand back some of the old material first.
I have 64g in mine after CG trimming. Battery is a 1600mah 4.8v Nimh @ 90gHow much nose weight have people had to use? Seems like its gonna be a lot.
