alex_pozgaj
Active User
Hello,
I was notified by two Wing Helper users that on MacOS, starting with one of the OS updates, there is a bug leading to spurious crashes respectively "hanging popup windows" showing the values converted to inch. In the following few days, version 1.7.1 will be released, with the fix for the crashes and an option to turn off the additional popup windows:
If you turn the option "Show converted values" off, the annoying issue with the windows that are not removed correctly is avoided. I am still searching for a better solution, but at least for now, that's what I was able to find.
If you want to give the test version a try, you can fetch it from this link. If all goes well, I expect to release this version in the coming few days.
Kind regards,
Alex.
Kind regards,
Alex.
