timrowledge
User
I have a pair of M9 Hall gimbals in my Taranis X9E. They've been doing their job quite nicely since 2018 but now it seems the sensor on the elevator axis is failing.
The symptom is the elevator reacting very slowly, almost as if it has a decidedly humpy & non-linear curve with slow-down. Very odd. It *isn't* the servos because the problem shows up in the channels monitor page on-TX. I spent quite a while examining the programming to make sure it wasn't an actual curve with slowness but the simulator worked as expected. After dismantling the TX and pulling the tiny sensor board to inspect it, to my surprise things started working properly once I reinstalled the sensor. I spotted a tiny bit of debris and concluded something had been interfering just enough.
Unfortunately today the problem is back and I rather suspect that means I need a replacement part. I doubt I can get a replacement sensor easily, so that means the entire gimbal - unless anyone has ideas to the contrary? Has anyone else seen this kind of problem?
