D
dadboldt
Guest
I've had a Taranis X9D for several years and have 8 planes I fly regularly with it and have never had any problem with the system. Recently I built a new plane (20cc gas Phoenix Edge 540) and experienced a problem I had not seen before. During bench tests I was getting intermittent loss of communication between the transmitter and receiver. I changed the new receiver (X8R) with another new receiver (X6R) and had the same issues. I changed batteries, antenna positions, etc and could not resolve the issue. So I set the plane aside and instead built a new electric foam Skipper using the new X6R receiver. I didn't expect a problem but on it's maiden flight I got a low RSSI warning right at liftoff and critical RSSI warning as I banked back to the runway. That happened right after a long trouble free flight of my Something Extra using the same transmitter. I also did a range test with a friend's Taranis bound to the Skipper which gave critical RSSI results as well. Those two facts caused me to rule out a transmitter issue in my mind. I then took a proven receiver (X8R) out of one of my older planes and put it in the gas Edge 540 mounted just as the prior receiver and got great RSSI results on a range test.
My analysis leads me to think I have two bad new receivers, as crazy as that may seem. Or perhaps the antennas on the receivers (flat PCB on the X8R, whisker on the X6R) are not performing as well as the plastic ends on the older receivers. My question is whether anyone has experienced similar problems?
