I have been looking for longer antennas for the Archer SR8pro and for the SR10pro receivers. I have a couple of planes that are Carbin fiber lamented over plywood, and I want to get the antennas outside the plane, away from the CF. I had a 30cc Extra 260 crashed on the second fight as I was coming in for a land and close to the end of the runway. I have found some antennas that are 250mm and 400 mm long which would be a good length for what I need to get the antennas outside the plane. I see that there are 2 different types of them, there is a IPEX1 dipole 2.4GHz and Ipex4 Dipole 2.4GHz. Does anyone know if both of these types of antennas will work with the SR8pro and the RS10pro, If they will work witch one should I use? It looks like the end of the antenna is larger then the other. I think the IPEX4 is larger then the IPEX1 antenna.
any Help would be greatly appreciated.
