Logical switches
Planemad
Hi. I'm doing a twin hull project/twin engine/props. The rudder is kinda marginal. I'd like thrust on both engines when straight ahead, and left or right motors when turning right or left respectively.( It's slow speed sailing/motor assist kinda thing.. To assist tacking, manoeuverability etc)
I've managed to set up 2 logical switches. a<x and a>x for the rudder (-30 and+30 respectively ) and those 2 switches are working in a logical fashion. I just need another condition? Couple more logical switches? to switch off(-100) left or right motor, when the rudder activated switch is active? That's where I'm kinda stuck lol. If anyone has a suggestion it would be great. Thank you
Just throwing out another idea. Perhaps a throttle curve tied to each motor that is driven by rudder. I used the "ADD" functionality to add the value from the curve to the motor output, so once the rudder goes left enough it will start adding a value. If the rudder moves to the right enough, it will start subtracting a value. For the "other" motor, I just used the !curve. I have also attached the model file of this example.
