Logic Switch challenges. Translating OTX format to Ethos
S
stepheneadams
Guest
Trouble translating OTX logic switch language to Ethos format. The image reflects my OTX two-factor ignition process for my gassers. I am trying to do the same. In this case I want to use SH and SI (on the back) both held for 2 seconds to turn the ignition module on. This is what I have now:
L01 IGN_1 Sticky SH
L02 IGN_2 Sticky SI
L03 ARM. L01 AND L02
Ignition Free Mix would use L03 set for Channel 6 Output
With the above...L01 and L02, toggle ON; however, the above logic only flashes L03 ON then back it goes back to OFF state. How do I get this to latch the Ignition on ? THEN, how do I toggle the ignition back to a OFF state?
How would I set with /both L01/L02 for a 2 sec hold?
Finally, I just bought my first electric. Turbo Timber. Would the same idea above work? Only L03 is assigned to Throttle mix.
I have the simple two-factor operating yet have not figured out to have SH held in position for 2 sec before going True.
LSW1. IGN-1. Edge of SH(down)
LSW2. IGN-2. IGN-1 AND SI(down)
LSW3. Arm. Sticky IGN-2 / SH(up)
