Masterpiece
I have tried the new G-RX6 and RX6R receivers on my Taranis X9D with the external XJT module and they bind beautifully everytime, BUT the module goes into range failure mode beeps (constant beeps), even though the radios RSSI is showing full bar signal reception.
It really sucks and the beeping is so @#$&ing annoying (why have this feature in the module if the radio already does it anyway????).
The module was purchased locally (Austalian vendor) only a month or two ago, but i feel that it's firmware needs updating so this bug can be sorted.
Has anybody else had this same issue with a similar set up? And if so what ideas do you recommend I do so i can use the module with the new "RX" series receivers?
Any feedback is greatly appreciated
Thanks
Glen
PS: the external module works fine with the older "X" series receivers (ie X8R, X6R ..... etc)
Thanks
Glen
