Issues with SR10 Pro
I recently installed a SR10 Pro in a new 45cc warbird. All servos are digital. I have a total of 8 servos plus 2 electric retracts, using all 10 available PWM pins. Redundancy is provided
by a M+ connected to the S.Bus In of the receiver. The M+ and the SR10 Pro are registered to the radio with different UIDs (0 and 1).
Two LiFe batteries, with their own heavy duty switch, plugged into the XT30 battery ports. Firmware is latest (2.1.6).
First of all, let me say that the SR10 Pro is the reason I updated my X10S to ACCESS. 10 PWM pins, stabilization and dual independent battery inputs make this receiver
IMMO the best receiver for large warbirds, AT LEAST ON PAPER.
However, I have discovered two issues.
1) I have a number of sensors attached to the SR10 Pro via S.Port: Airspeed sensor, Cells sensors (plugged into the balancing plug), RPM sensor.
To have all the sensors show up in the telemetry feed on the radio, I need to cycle the power on the Rx several time. It is a hit or miss: The internal sensors (RxBt, RSSI, VFR) show
up consistently. The other sensors, not always. Sometime I have to turn the switches on and off 3 to 4 times before all sensors show up.
This issue does not seem to be related to the number of external sensors hooked up. I get the same behavior even with only the airspeed sensor attached.
2) When I switch stabilization on in flight, RxBt (blue in the plot attached, scale on the left) shows a significant voltage drop,
from 6.6V typical of charged LiFes, down to 6.2 to 6.3V. Interestingly, the Cells sensors only report a rather smaller drop (about 50 mV, green and red) at the battery.
In the attached telemetry plot, the time when the stab is on is circled in red. Note that with the stab off, Cells and RxBt show basically identical readings.
Also (not shown) the drop is worse at higher speed. It is possible the plane develops oscillations, though not large enough to be noticed when flying without stabilization.
It makes sense for the stabilizer to work the servos harder, with higher currents flowing out of the battery. However, the rather small drop at the battery suggests
that the currents involved is probably a few amps at the most. So why is the RxBt dropping so much? I am inclined to think that the drop does not occur between the battery and the Rx (the lines are short, and the switches are heavy duty type, bought from a reputable vendor), but
rather is due to the circuit that separates the batteries. This separation can be achieved in two ways: a conventional diode or an ideal diode. A conventional diode will introduce a voltage drop when
forward biased. The drop seems to be consistent with a Schottky diode. An ideal diode, on the other hand, does not introduce a significant drop, but requires more circuitry.
For example, on the RB-20, the board shows to nice MOSFETs indicating that ideal diodes are used to achieve separation.
At this moment, I have not measured to actual current out of the batteries, so these are just hunches.
I really do not need the stabilizer on this warbird, but I think that the second issue should be discussed. It is a significant voltage drop. I use LiFes, but there are still lots of people out there who use NiCad, and
in this case, the drop would affect at least how servos respond. Also, the drop means that power is dissipated in the Rx. That could cause issues too.
The first issue is, however, annoying. Maybe I just got a bad Rx (bought it from Aloft).
Would be interested to know if other people out there had similar experiences.
Really nothing to add. I see that the SR10 pro is now at FW 2.1.7 to correct some start up issues. I wonder is your sensor capture issue is addressed.
Thanks Konrad. I will upload the new FW. However, I do not think that the voltage drop issue is related to that, and I would like to go to the bottom of it. Mostly, I'd like to rule out the possibility that
there is something wrong with the hardware itself (like a cold joint or something like that that causes an anomalous internal resistance). I really would like to hear from Aloft on this...
As this is a new product I don't think the dealers have had much experience with it. FrSky doesn't actually give the dealers any inside information on circuit operation. It might be best to ask FrSky. (Sorry that was a bad joke).
When dealing with power issues the engineer will want current numbers. Also what size and age are the cells. I suspect there might be an issue with the voltage meter across the battery. Can you get a reading with a known good Digital Volt Meter?
Gyros are very hard on batteries with all those start and stop current surges. It is my experience that they cause more harm than good. Unless you have set up the ship to be inherently unstable I'd leave them out (off). One exception to this rule is a gyro on the rudder to tame unwanted dutch roll with some aircraft. Many scale models have too small a vertical fin.
I am confident on the voltage measurements, confirmed with a good digital multimeter. Batteries are new, 3000 mAh each. Tests were done with batteries fully charged. I think there is no doubt that the voltage drop occurs somewhere between the battery and the RX, and it is not due to the internal resistance of the batteries. I agree with you that I do not need the Gyro on this warbird. If this drop is normal, I can live with that (just keep the gyro off). But I would like to be sure that this is not a symptom of something that can cause some catastrophic failure
later on (like a cold solder joint). I have experienced a plane losing electrical power shortly after take off and the results is not pretty. One of the reasons I picked the SR10 Pro is to have true battery redundancy. When I have time, I will try testing the setup applying to one of the SR10 pins a known current. I have done it in the past with a small electric motor + ESC, which draws up to 5A (the maximum rating of standard servo plugs). By controlling the current out on the bench, I am hoping to draw a diagram of voltage drop vs. current, independent on the Gyro
I hooked up a brand new SR10 PRO yesterday and right from the box the same situation 7.7V at servos with 8,4V at battery...
Till 2 days ago I made approx 30 flights on my old SR10 PRO with no problems.. 8.5V source and 8,5V on servos. Before the last flight suddenly the Voltage dropped to 7.9V...
If it will not be adressed by FrSky I strongly urge every one to stay away from this receiver.
That is worrisome. One thing is if the voltage drop is consistent, and determined by the circuitry used to separate the batteries. An entirely different thing is when
the voltage drop appears all of a sudden. That indicates a failure in the circuitry. I wish Wayne or somebody higher up in the FrSky food chain would take this issue up.
I guess the important questions are
1) what type of circuitry is used to separate the batteries?
2) what is the normal operational curve of the circuit (Voltage drop vs. amps)?
BTW, diodes are fine, as long as they can handle the current. Some of the low-end SmartFly power modules use diodes for the separation, but clearly
indicate in the documentation that a 0.6V drop is to be expected. It just would be nice to know for sure, so we can set our telemetry alarms and know when
things are operating out of specs...
Wojtek,
when the problem showed up on your SR10Pro, were you using stabilization? Does the voltage drop occurs without stabilization?
