Is this a replacement antenna for the Taranis X9D+?
That one doesn't directly fit your X9D+ (presuming it's not the 2019 version) as it has no connection to screw it on. You need the soldered version.
Be carefull soldering yourself if you don't have the skills, it seems to be easy to damage the transmitterboard (XJT module) due to static. Then it's better to let a skilled person do it.
Static is not normally the issue, but too much heat will damage the tiny little traces you need to solder. We rank this soldering job as rather skilled as better equipment and heat management are strongly suggested. With this said, countless folks have made the repair at home.
