How to configure receiver's PWM output to NOT be a servo
Farhad
Hi. I just got a Taranis Tx with FrSky R8 Pro receiver. It has 8 PWM outputs. I'm flying a fixed wing airplane. I have everything configure and working. I have one special need, that is the output of CH 6 is a light, not a servo.
I want to configure CH 6 to output a constant HIGH or a LOW, but not pulse PWM between 1000us - 2000us. That is, the output is not a servo. It's a light. I want to manually turn this light on or off with a switch.
How do I define the output of this channel to a continuous high or low? (It is not connected to a servo)
thanks.
Sounds like a job for a transistor.
Why would you have problem with a 22ms pulse?
The output of the RX (signal) is not to be used as a voltage source. Now it can be used to drive a transistor and the transistor would switch the Vss to turn on your light. As the RX is putting output a pulse you might want a resister capacitor (RC) circuit to bias the transistor.
Or better yet get a cheap amp from a $2 servo and use it to drive your light.
That's not how it works, you need an external RC switch that takes the PWM output and switches a transistor/relay based on the value.
On internet, search for:
1. "pwm switch" or "rc switch"
2. "pwm relay" or "rc relay"
3. "rc engine ignition kill switch"
4. "brushed esc"
5. "rc led controller"
Attached the PWM pin of the receiver to an oscilloscope and it showed the 1000us, 1500us, and 2000us when changing the 3 position switch. PWM is at 50Hz, 3.3V. I had thought I could have it always stay high and connect it to the base of a transistor then I would be done :-)
If I don't program my own micro-controller to read how long the signal stays high, a PWM switch is $13 on Amazon (Canadian). Thanks for the clarification, I get it now.
I wonder if an RC circuit with an op-amp comparator is possible for controlling the transistor. t < 1300us, 1350 < t < 1700, t > 1750us. For me the most obvious and easiest way of doing it would be to program a microcontroller.
The best way to achieve a switch type function is one of the servo / channel control switch. They are low cost and work perfectly. They can be purchase for under $10.
