Weight Vs Glide angle.
Hi Guys there seems to be some confusion regarding the effects that weight has on a glider’s angle of descent (Glide ratio) or the distance the glider will fly for a given weight at normal flying airspeeds and at minimum/maximum weights.
In fact, the weight of the glider has no effect on the glide angle or the glide distance. But it does have great effect on how fast the glider flies and how fast a heavier glider will cover the same flight distance as a lighter model.
Weight variations in aircraft weight do not affect the glide angle provided that the correct airspeed is flown. Since it is the lift over drag (L/D) ratio that determines the gliding range, weight will not affect it. The glide ratio is based only on the relationship of the aerodynamic forces acting on the aircraft and not the weight.
So, for example if a glider has a 50:1 glide ratio, then it travels 50 feet for every foot of altitude lost. The best glide speed is the airspeed at which, in still air, the glider achieves its best glide ratio. This is also known as the best lift/drag (L/D) speed.
To elaborate a bit, in Aerodynamics, the lift-to-drag ratio (or L/D ratio) is the lift generated by an aerodynamic body such as an aerofoil on an aircraft wing, divided by the aerodynamic drag caused by moving through air. So, L/D can be used to describe the aerodynamic efficiency under given flight conditions. The L/D ratio for any given body will vary according to these flight conditions.
I don’t want to get too technical here, and disappear into a load of boring math, but for reference:
The lift coefficient is defined as: CL = L/qS, where L is the lift force, S the area of the wing and q = (rU2/2) is the dynamic pressure with r the air density and U the airspeed. Similarly, the drag coefficient is written as: CD = D/qS, where D is the drag force and the other symbols have the same meaning.
OK that’s over!
For an aerofoil wing or powered aircraft, the L/D is specified when in straight and level flight. For a glider it determines the glide ratio, i.e. distance travelled against loss of height.
The term is calculated for any particular airspeed by measuring the lift generated, then dividing by the drag at that speed. These figures vary with speed, so the results are typically plotted on a 2-dimensional graph. In almost all cases the graph forms a U-shape, due to the two main components of drag. The L/D may be calculated using computational fluid dynamics or computer simulation, though at our low Reynolds numbers, the results may not be 100% accurate. It is measured empirically by testing in a wind tunnel or by a free fight test.
The L/D ratio is affected by both the form drag of the body and by the induced drag associated with the flying surfaces creating a lifting force and it depends principally on the lift and drag coefficients, the angle of attack to the airflow and the wing aspect ratio.
The L/D ratio is inversely proportional to the energy required for a given flightpath, so that doubling the L/D ratio will require only half of the energy for the same distance travelled. This results directly in better performance for a powered plane or glider.
Lets, say you had three versions of the same glider, a light version, a medium weight version, and a heavy weight version on the top of the same hill, you would find that if you threw them all off one by one, the heavy one would reach the bottom first, the medium one second, and the light one last, all in terms of time. But you would also find that they had all flown the same distance beause the glide ratio had not changed. Logically then, if you had a light glider that could stay up in light lift, then the same glider in medium and heavy versions of it would also stay up in the same lift conditions.
You will see that Aeroic normally offers three layups. "L", "S", and "SS" Please do not think that these designtions are related to weight at all, instead they are rated as measures of stiffness and durability.
I hope that helps to explain.
OK that’s over!
