Horus X12S upgrade to Ethos
ninod
Just ordered the
Just ordered the FrSky ACCESS Upgrade ISRM RF Module for Horus X10/X10S/X12S. Can't wait to upgrade and have any recommendations or issues with doing this. Thanks.​
Nino
Just pay attention to the antennas when you are taking it apart. they are tough to keep track of. I like to take a picture of them to refer to while re assembling...
Then you will have to flash the new firmware once it is back together.
Which antenna. I know the original board has 2 antennas and the new board has 3. Is it for the 900Mhz side and where do I connect it to?
Nino
I can't remember the antenna placement on all these radios... The new board will have 4 - IPEX 1 connections. Plug in the antennas that you have in the same place, and IF you need another, just add one, and tape it inside the radio somewhere out of the way.
I believe that as the radio comes it has one internal and one external. I too have read that you just add another inside the case.
Does the ISRM upgrade force migration to Ethos?
No; I upgraded one and had Aloft upgrade one and both are using Open Tx. But I understand you can flash with Ethos if you prefer. Had Chris do the one I sent to Aloft and he installed Open Tx for me.
Raymond
Thank you, Chris. Another question, apologies in advance for sounding ignorant: After installing the new board, do I need to flash the 2.x version of the firmware? And am I correct in understanding this would require me to flash my X8R receivers to version 2? Would version 2 even work on the older X8R receivers, or would I need to replace them with the newer receivers?
You will need to install the v2.1 ISRM version onto the new X12 module and once this is done the receiver needs matching firmware as well being v2.1.X. This will apply to all receivers although mostly the Archer receivers appear to already have this installed from new.
Thanks, Henny. In your opinion, would it be easier (although expensive) to replace my current X8R receivers with the Archers once the transmitter upgrade s completed? I've got 5-6 X8R receivers.
The X8R is a perfectly fine receiver even though is can only run ACCST operating firmware. The only reason to use a later version receiver is to gain the Flight Pack voltage telemetry perimeter or the faster TX rate option (4ms) for Archer, other than that you wont find any issues. Its just as easy to run either ACCST or ACCESS transmission protocols which is selected in the TX when you are about to bind to the receiver, and of course is dependent on the receiver type.
Thanks for the answer to the X8R question, Henny. But now I have yet another question: The OEM battery pack on my X12S will charge only 70-75 percent. After installing the the ISRM board, would I need to install a higher voltage battery pack, or just replace the current one with another duplicate of the OEM? If I should try something else, do you have a recommendation on a replacement? Somebody at our club suggested maybe a LiFe battery, but I think I read somewhere the new board requires more power, so I'm at a loss. I also believe I would need to replace the OEM charging module if I try something different. Your thoughts?
I never considered myself to be stupid, but I'm thinking perhaps I have over-estimated my capabilities. I'm not a mechanic, but armed with a Chilton's manual with step-by-step instructions, I can work on a car. Is there anything like that for installing the ISRM board on my X12S? I have been using FrOS on my transmitter since I bought it in 2017. The last FW upgrade I did was 1.5.X. I installed the ISRM board yesterday, and then tried to upgrade the FW to support it. I read in one chat group to install 2.X.X for the X10 or X10S. I tried to do that in the manner in which I installed previous FW updates, but it didn't work. Then I finally worked up the courage to try to install OTX, hoping that would make the FW update easier. OTX wouldn't load. Admittedly, I might not have done all of that correctly. Were there some prerequisite steps that knowledgeable people would automatically presume I would (or should) have done before attempting to install the ISRM? For grins and giggles, I tried connecting to one of my existing X8R receivers, and (Surprise! No, not really) it wasn't bound anymore. I know I have to update the FW on the RX, but I'm not sure how I'm going to do THAT if I cannot update the FW on the X12S. If this is not the right forum for this, please direct me to the right one. Many, many thanks!
It is true, what they say: that reading is fundamental. I still have ISRM module in the X12S. I'm still using FrTX. I saw the failure to enter flashing mode included holding the enter button. I had loaded this file into the FIRMWARE folder on the SD card: X12S_NEU_1607_0314_frtx.bin. Flashing loaded as normal. When pressed to restart, got the message that said updating and "this may take a few seconds." And then.....Nothing. Just the advisory that it my take a few seconds. Should it be longer than 3 minutes? I held the power button until X12S cut off. Waited about a minute, then restarted. Got the same screen advising it may take a few seconds. Have I successfully bricked my Horus? Can I resurrect it? Battery was at half charged. So it is currently turned off and on the charger.
