ninod
I decided to mod the battery in order to charge it on the bench with a standard battery charger. I took the battery out and cut the lead red and black and inserted a heavy duty servo lead in between. Then routed them through the JR Module area. When Fast charging is required I simply open the JR Module area and disconnected the two wires as shown in the pictures below and plug the battery end into the bench charger. Your still able to charge the Radio through the AC adapter if so desired.
