gp49
Need some info/education on a HV servos. I purchased Corona DS239HV servos, from Aloft, to go with my new build. The servos are rated 7.4 volts. The plane im building is a DAW Ka6 3m EPP foam glider. My plan was to use 4x AA Eneloop Pro batteries. This is a full house glider, so wings will be 2x HS225mg for flaps, Corona for ailerons, and more HS225mg for rudder, elevator and tow release.
Are the two HV aileron servos going to be "ok" at the lower volts?
