I have three idle settings for mine:
A very high idle for starting
A high idle
A low idle.
Make sure the "Throttle Trim Idle Only" box in Setup is checked.
For 3 settings, put values into GVAR 1, 2, and 3 in Flight Mode 0 (I use 35, 15 and 10 respectively, but your amounts may vary).
In Throttle Mix, add 3 lines:
+= I3:Thr Weight(+GV1) Switch SG↑ No Trim
+= I3:Thr Weight(+GV2) Switch SG- No Trim
+= I3:Thr Weight(+GV3) Switch SG↓ No Trim
Of course, the above assumes that you have Throttle listed as Input #3 on the inputs list. Use whatever yours is. And the switch used can of course be whatever you want.
Up gives very high, middle gives high, down gives low.
For setup, get the engine running, and with the switch in the appropriate position, go in and adjust the GV number to give you the rpm you want for that level.
Note that your trim level will still work as a "master" trim - varying the three levels the same amount up or down, if a bit of tweak is needed on a given day.
