Shoelace
Hey everyone, I'm getting pretty frustrated and am in need of an answer to something that's probably very simple. I'm trying to program crow in my new plane. Somehow I've done this twice before using the preset butterfly mix with zero issues, but now no matter how much I try I can't seem to swing this.
The issue is that if I am using the mix, when I try to set the ailerons to go up when I move my throttle stick down, it's just not setting. So, for example, if I dial in the weight of the aileron to -75%, then as I do that, the ailerons are going up while the flap stays neutral. If I were to reverse this weight then obviously they go down. I need to set this so that they stay neutral and then only are deployed when I activate the throttle. I've tried doing, "After first position," and "After last position," with no difference in effect.
I'm sure I'm just missing something SUPER simple here, but I just can't seem to figure it out.
Thanks.
Thanks.
