2 cell under-powered?... The 2s is a bit under-powered, but still fine. And it's a 2200 mAh, so nice long flights. This is my daily flyer now.
As power from an electric motor is defined as V x A = Watts. If we are limited in voltage we can make up for the lost power with current. So if your motor and ESC have the head room just up the prop load to regain the lost power from the lower voltage. Going with a larger pitch ups the plane's speed. Increasing the diameter improves the static thrust.
Now an aircraft flies as a function of speed. So if lowering the voltage you will be lowering the RPM of the motor. To regain the lost speed from the lower RPM by increasing the propeller pitch. This often regains what a lot of folks call loss of power. Often times it is really more a loss of pitch speed.
A crude rule of thumb to keep the load load about the same when adjusting the prop is: if going down one unit in diameter you can up the pitch 2 units. Of course the reverse is true if upping the pitch one unit you would need to use a smaller by 1/2 a unit diameter prop.
When working with electrical power an amp meter is a must!
