GWS-PT-17 as first biplane?
  • Thread starter Thread starter GrandpaToad
  • Start date Start date
G
GrandpaToad
Guest
Hi all,
I'm still a little new to this but I love the look of the biplanes. What does anyone think about the PT-17 as a first biplane?
It would be great. But it is not a good first, second or third airplane. Mainly because the top wings on most biplane are far too easily torn off. The main limitation is that biplanes take more maintenance (repair) as the struts are easily damaged.
Thanks for your reply. I never thought about wing damage and repair. I know this is a controversial subject but could a person add safe technology to the plane?
Yes, but why? If one still needs SAFE or Gyros one still needs to practices adverse attitude training with less desirable models (basic trainers).
The PT-17 is a nice flying model. With the drag from the wings and struts keeps the speed down even in a dive, gving you a bit of time to think. Again, the only reason I don't think it is a good primary trainer is the durability of the upper wing attachment.
I have heard that it is a bit of a challenging build and the GWS foam is pretty brittle so one bad landing and it will need some repairs?
Not in my book. I like EPS foam because it is easy to repair and is so much lighter then EPO foam. To repair most EPS foam just use the hot water process to expand the dents. Works much better for EPS foame than the heavy EPO foam. For really badly damaged foam. Cut it out and use any EPS packing foam you might have around the house. Glue the block back in with foam safe CA or epoxy. (I find epoxy the best) sand to shape. As to adding strength use fiber glass packing tape. heck even regulare packing tape adds a lot of durability with little weight.
I find that EPS planes last longer than EPO planes because they are lighter and fly better. They also last longer as i'm able to keep them looking better longer. I've said it many times EPO foam is the wrong material to make model airplanes out of.
The only downside I remember with the PT-17 was the thin cowl.
Interesting, I didn’t know there was different types of foam used for airplanes. What kind of epoxy do you use for EPS foam?
Anything but 5 minute. I like to use 15 minute as I'm not doing any laminating. I like to add a lot of micro balloons to ease the sanding. We don't need or actually want the strength of the epoxy glue. As EPS foam is a plastic glues that rely of evaporation should be avoided. Some folks like contact cements. But if there is any need to slide the parts in place, contact cement is a no go.
Hi GT,
The PT-17 is an OK plane, but there is nothing 'trainer' about it, so only fly it if you already have some experience. If you do, it's fun.
A few things to watch out for: the wings have no dihedral, so the plane will not right itself. The struts are rather soft plastic, so the upper wing will move relative to the lower, unless you beef up the struts. Definitely watch which strut goes where, as it affects the decalage (angle between the two wings) which makes a difference, as I found out...
Make sure you carve out the battery cavity as necessary before you glue the fuse together. I didn't, and later found that I could only get a 2s in there - which actually is enough for basic flying, but a 3s is more fun. You don't want the battery inside the fuse - makes it very hard to get to, what with all those strut screws.
The short nose makes it inherently tail heavy, so do ALL you can to keep the weight up front. I had to use a heavy metal spinner to balance mine.
Don't use that silly GWS adhesive - it takes forever to dry and adheres marginally. As Konrad suggested, use Foam-Tac, I use BSI 'Foam Cure' (Aloft has it), or even WeldBond. And remove the paint before you glue to the foam, to be sure!
And lastly, beef up the front end with the motor mount. After the first hard nose-in, it was a mess. I glued a thin plywood 'firewall' plate onto the front, which worked well. Needed that weight there anyway. Have fun with it!
Steven
Start with a Slow Stick, they are a great trainer plane and take abuse well. Save the Pt-17 for later.
How comfortable are you with your current trainer? Equally important is how limited do you feel with the constraints of a trainer?
In my day we had basic trainers like the Slow Stick. Then we stepped up to aileron trainers (thick semi-symmetrical wings). Planes like the Great Planes Super Sportster were such aileron trainers. Once we got comfortable with those then it was just a speed and wing loading thing as to the performance of the ships we (you) were comfortable with.
If you are comfortable with ailerons then go with the Pt-17. Like I said it is more of a 3rd or 4th plane and NOT a basic trainer.
As a good 1st biplane it would be great!
I’m trying to look forward down the road. I doubt I will fly it for sometime. I just really like building planes and see them in the air.
GT, I'd say go ahead - buy it and build it. At this price it's a great deal, and whenever you feel ready you'll be happily flying it. Just don't pimp it up until you've got some air time on it, to save yourself some heartache in case you dump it early on...
I agree with Wayne's advice on motors and ESC's. I started with a 3s battery (internal) setup, but switched to 2s because it's thinner - the only way I could fit the battery in the external compartment. The 2s is a bit under-powered, but still fine. And it's a 2200 mAh, so nice long flights. This is my daily flyer now.
They would work, but 1000mAh won't last very long. I've set my Tx timer for 13 minutes, at which point my 2200 mAh 2s battery is down to ~25% capacity, a safe level to stop. My motor is a Cheetah A2217-6 Brushless Outrunner, 1500 kV, with an 8 x 4 prop. Battery and 20A ESC stay nice and cool.
If you can fit 2 batteries side-by-side in the slot, that might help bring the CG forward.
“If you can fit 2 batteries side-by-side in the slot, that might help bring the CG forward”
How would that work?
Who makes the battery that you are using?
