GWS IPS Brushless replacement
  • Thread starter Thread starter estill
  • Start date Start date
E
estill
Guest
I'd like to get an old Mini IFO back in the air. It is basically a kite with an GWS IPS geared setup on it. I'm thinking a small (22xx sized) and low kv outrunner should work, but I really don't know how to interpret the specs to determine it if would work. My best guess is the kv rating should be between 1000 and 1200. On 2s that should allow me to swing an 8 or 9 inch prop, or would it? My biggest concern is weight. I know the it IPS comes in right around 30g. Anyone have any suggestions?
As an alternative, if Aloft would start selling the pico stick I'd buy a handful of those and be happy.
I've had good luck with outrunners that are about half the weight of the IPS as substitutes for the geared IPS system.
something like this works great.
In your aplication I think the mounting will be the biggest issue.
Thank you.
I'm not too concerned with mounting. Between my 3d printer and laser engraver I should be able to come up with something light weight and sturdy. I figured I'd start with a 3d printed mount. If/when that fails I'd cut a backing plate out of light ply, and epoxy a piece of carbon fiber tubing (think arrow shaft, but smaller) to it.
I have a couple of ideas for more reliably mounting the electronics overall. I never really like the eye-ball it and epoxy a piece of balsa.
If you like the smaller props this motor might work well.
Please note that the IPS (180 size can motor) used by GWS was only good for about 2 amps before the brushes started to burn. These outrunner can handle twice the amps and maybe three times or more the power.
I remember that about the power, and playing with a few different props. I had settled in on the 10x4.7 SF. Anything modern motor will be different from anything I remember. I figured go to a smaller diameter prop to reduce the torque effects. So I'd start with the GWS 8x6 slow fly/floppy ones, and probably try the 8x4 DD.
As it sits with the old electronics, and minus a battery the IFO weighs 104g. With current electronics, and I'm probably going to build a new frame, I'm guessing the AUW will be right in the 100g range. Looking at specs, the two motors you recommended should be capable well over 200g of thrust, so I'll be looking to limit the throttle for fear of ripping everything apart.
Konrad, Thank you for you help.
I was able to get everything installed on the old frame, and all I can say is "wow the pilot is really bad." I need to get out to somewhere bigger than my backyard and get the trims set.
In case anyone stumbles across this thread later.
The power system works great. Right now I have the EMax GT 2203 1560kv swinging the 8x6 slow flyer prop. I went with the Dualsky ECO lite 12A esc. It flies comfortable at 25% throttle.
