turfdoggie
Hello,
I have a .60 sized Ultra Stick with an Access GR8 receiver installed. I have the antennas separated and mounted perpendicular to each other, but I'm getting low RSSI warnings on my X9D+ 2019 radio, at pretty short distances from the transmitter. Other airplanes in my stable don't give similar warnings, so I'm guessing I might have an issue with antenna placement.
Just to be on the safe side, I'm considering mounting a satellite receiver in the airplane. This will be my first satellite configuration, and I'd like some suggestions on which FrSky receiver models will work in this capacity, along with recommendations on which one to pick (from the available models). Also, I'd like suggestions on where I can purchase the wiring to connect the satellite Rx to the main Rx. I'll happily purchase the cabling from Aloft, if that's an option.
Thanks in advance - I really appreciate the help!
Mitchell
Mitchell
