GR8 RECEIVER TO IKON 2 FBL MODULE WIRING FOR S-BUS
There should not be much difference in basic Sbus control. As I understand it FRsky adopted the Futaba Sbus protocols and added some additional functionality. I use the Sbus with Adru pilot using the PX4 and all operates fine.
There should not be much difference in basic Sbus control. As I understand it FRsky adopted the Futaba Sbus protocols and added some additional functionality. I use the Sbus with Adru pilot using the PX4 and all operates fine. Thanks henny im waiting on a neuron sbec,,ill try futuba s-bus in program in ikon 2 and use futuba channel sequence
F-Port is a combination of S-Bus and S-port on the one connection. Some flight controllers can support it. I do not know if ikon-2 supports this protocol, it's a question to be answered by ikon.
If Ikon does support it you will need to flash the receiver with the F-port version of the receiver firmware. All it really does is reduce connection between the receiver and flight controller by one wire.
it also eases up telementry conn that seems alot of people are having thanx everybody i am a newby to 2.4 stuff but been flying for a lot of years
