Hello! I just upgraded to an X18 from a Futaba 9cap and am looking for some feedback on my setup and range test results. A week ago I was flying the Alpina at 4 corners and got a “Low RSSI” alert while still fairly close in right after partial fly-by - maybe less than 100’ out.
Today I did a more “proper” range check at the Berkeley Marina (wide open, flat, no obstructions) with the Alpina mounted on a wooden tripod. A lazy-susan bearing allows the model to turn or weathervane.
Installation: Archer GR8 (plus an Archer RS as a redundant rx). GR8 antennas are oriented 90 deg to each other in a vertical plane starting near the fuse bottom centerline and radiating upwards and spanwise towards the elevator/Rudd pushrods. The Alpina fuse is fiberglass but I think there may be a straight 1/4”-3/8” wide run of carbon tow down the length of the fuse on each side. Also, the elevator.rudder pushrods are plastic sheathed music wire running parallel to the suspected carbon tow. See cross section image.
For the test in RANGE mode, I walked away to the rear of the Alpina keeping the TX facing the Alpina. I got “low RSSI” warnings before I reached 90’ - probably around 70’-80’. At 90’ I stopped and my son slowly spun the Alpina on the tripod through 360deg. Then I moved out to 100’ and we spun the Alpina again, then out to 110’ and another spin…
I’ve included 2 graphs from Companion with some notation added for model orientation, etc. On the 1st graph I forgot to put the TX in RANGE mode. The 2nd graph is in RANGE mode.
It looks like the signal gets blanketed the most from the equipment up front. Are these results reasonable for a range check or should I be looking for better results?
