hotdogx
User
I have an X-Lite S transmitter and Archer GR6 receiver installed into a DLG, running ACCESS. The DLG fuselage is fiberglass - no carbon. The receiver bound just fine and all the controls are working as expected after programming. Telemetry is working fine. However, I am having range issues. I do not get the recommended range on the range check, and even at full TX power I get RSSI low and RSSI critical wanrings when the DLG is only 100' - 200' away from the TX, with the DLG well above the ground. I changed the RX antennas so that they are sticking out of the fuselage sides at 90 degrees to each other, and it made no difference at all. I also have a Horus X10S TX running ACCST on three G-RX6 and two G-RX8 receivers, and I have had no range problems at all.
Any ideas on how to solve this problem? I'm wondering if I have a defective GR6 RX.
