I've heard of that one, but never tried it. Yes, my current project is an art, but beyond that, it's going to be my "ultimate" mustang build. The one that rolls all my previous attempts at a super nice rc plane into one, with additions I haven't done before.AHH Yes, as has been said "to each his own"....
As far as fuel proofing goes, I always used thinned White Glue. It never failed me.
This was on new construction however. On ARFs it still works if it can stick to what
ever, if any, has already been applied.
Tom
Don't know if I have a good process for that. I like to freeze the covering using reusable compresses from the CVT store. Cold coverings seem to lift off easier. The adhesive doesn't grab a tenaciously. For adhesive that will be left on the wood I like to scrape it off with a carpet knife blade held at close to 90° to the surface. I find that sandpaper will load up and actually damage the wood more than the scraper.Konrad, a quick question. In your experience, what's best for removing ultraKote...trust me, just trying to peel it...leads to a lot of sanding to get the color pigment layer off lol.
From what I've heard, that trick is generally used on firewalls.So what part of the plane are you fuel proofing with the diluted white glue? The painted exterior or the internal bays and engine compartment?
Good thing is, I only have to do a rudder lol.Don't know if I have a good process for that. I like to freeze the covering using reusable compresses from the CVT store. Cold coverings seem to lift off easier. The adhesive doesn't grab a tenaciously. For adhesive that will be left on the wood I like to scrape it off with a carpet knife blade held at close to 90° to the surface. I find that sandpaper will load up and actually damage the wood more than the scraper.
Now I will say that Oracover (Ultracoat) is a lot easier to cleanly remove than Monokote (well the true Monokote of old) AKA: MoneyKote. Try not to use an iron as this tends to drive the adhesive into the wood grain. But sometimes there is no other way to remove the plastic film.
There might be some hints here.
Hobie Hawk Restoration
I don't use the thin stuff very often, usually medium. But my experience is a small amount of thin will pretty much cure on contact with a towel. I have never managed to have any glue get past the towel. If I am using thin CA, I will glue it up in the garage if I can.forum.alofthobbies.com
Wonder what it was, actualky..actually.. a diluted acetone? If so, wonder what was used to dilute..I used to use Top Flite Trim Solvent to remove color and glue residue when stripping iron on covering. Unfortunately, it is no longer available.
I'm thinking I'mI find that solvents drive the adhesive (color) deeper into the wood grain. I'd caution against using solvents on any surface that has a foam core.
Yeah, I can see that is a problem with foam. I used it on a open frame balsa frame. Presently I am recovering a Sig 4 Star and used Citristrip water based stripper because the old iron-on covering was delaminating. In retrospect using Citristrip on an open frame plane was a mistake because the goop oozed all over inside the plane into spots where I can't reach.
Been there, done that. Like I said I don't have a good process to remove the colored adhesive. The solvent just drove the color deeper into the wood grain. Please test in an inconspicuous spot. I hope you can come up with a workable process.I'm thinking I'm
Been researching this. A lot of guys have used Ironex, used for cleaning things like covering irons, denatured alcohol or acetone, both of those being applied with cotton balls.
This is where I'm lucky..my current project is fully sheeted and I only need to do the redder to boot (it's just the wrong color for the aircraft I'm trying to replicate. Stock is red, going back with cub yellow ultracote.I honestly am not bothered with the color oozing into the wood if I'm recovering with opaque color over it. My only concern is what Konrad said about solvent-based stripper penetrating into foam core wings. I also learned from experience that using a thick water based stripper like Citristrip on open frames made a mess when all the dissolved goop got inside the frame and made it hard to remove.
Based on years of flying iron-on film that don't last and require eventual stripping and recovering, I am starting to think it is better to do a more durable covering job to begin with. I am practicing recovering with Koverall and Minwax Polycrylic on an old Sig 4Star right now. I admit it is a learning curve and lots more work. I am hoping that the extra work is worth it in the long run.
Seriously Dude. Electric motors have no soul lol.Hey Guys,
You should switch to the big Hacker motors, I have been using them for years. My biggest one is equivalent to
a 200 cc DA engine, and swings a 32x12 prop. and no fuel problems. 42% (EXTRA 300 )
As an also benefit, there is no C.G. shift or weight shift during flight. In addition if you want to you can turn it on or off
during flight.
Tom
Electric has no soul.Hey Guys,
during flight.
Tom
