First I need to apologize to all participants for violating the safety line at Sunday’s race.
The day started off badly as I had left my wings for my 99° Redshift at home! So I was forced to fall back on my light weight 104° glass Redshift. But as the winds where real high at 9:00am I knew it wasn’t the ship I want to race. Now I had brought my untested 96° Redshift wings and all. So I performed its maiden flight. Made the adjustment this flight indicated. (I didn’t need to change much as I have a lot of experience with Redshifts). By the start of the racing the winds had dropped enough to make the light weight Redshift a viable tool race with. Love the way the light Redshift flew. But by the 3 heat the winds where getting high and the turbulence was making it difficult to place the light weight ship where I wanted. I couldn’t figure out the ballast so moved to the new 96° Redshift.
Well I’m here to say that the new 96° V tail worked even better than the 99° and so much better than the 104°. With the new 96° Redshift I was doing rather well (for me). This is even more surprising as this was the second flight with this model. I guessed the programing changes as dictated by the maiden rather well. Now the wind and turbulence kept getting worse so I added ballast, again to good effect in subsequent heats.
Now the bad news! I ended up adding all the ballast I had, 620 grams. I knew something was off as the spacer block did not come into the loading window as it had earlier. I knew something was wrong but told myself it must have been some tolerance stack up issue with all the spacer. What had happened was that the rear ballast stop had cracked free and was moving aft down the ballast tube. You guessed it, with the strong arm of my launcher
@Pinepig I had 620 grams of ballast shift aft 35mm to 40mm!
Wow, she was really responding fast to the elevator! I thought I has too much snap flap and was lowering it after each turn. (Mike Shellim’s templet allows this). At one turn the fast elevator resulted in a cut. So I bunted, and to make up time gave full race elevator out of a diving turn. Well, that drove the rear stop out of the ballast tube and the resulting very aft CofG causing the ship to rotate vertical. The Redshift shot straight up into the sun. There was nothing I could do but scream HEADS UP and watch in horror as the ship drifted over the safety line. At the top of the climb the nose flopped forward allowing some of the 620 grams of ballast to move forward. Much to my surprise I regained some control!
I called a mayday at turned into the landing zone. Much to my frustration I couldn’t get the nose down (I was still very tail heavy) and was pushed into the rear rotor that is the bane of all of us that fly the SLoT! The damage was moderate to heavy but at least I hadn’t hurt anybody!
@Doc James Hammond I have to say you have a magical wing there in the Redshift. It took some gross changes in the CofG to get her to actually let go Snap/Stall! As to elevator control with the 96° tail I saw no issues in the handling, ether in thermal flight of the test flight or the response at close to max FAI weight. I like how the Redshift tracked with the 96° tail no wiggle, well she was as good or better than the competition ! I’m thinking I can still move closer to the 90° tail, but fear getting into Horner’s 90° junction drag.
