Wanted to share details from Len's build that he emailed to us. He has granted permission for me to repost. Len made some changes as he was planning to highstart the Gentle Lady and he also added some washout to the tips (more on that below).
He writes:
My GL-EVO ended up with a ready-to-fly weight of about 11 ounces after all my mods. All I've done so far is an hour of hand launch testing which was 100% successful. Winds were gusting to 10+ mph. I experimented with CG location and found that there is a wide CG range. I originally set the CG just in front of the main spar, but that required some up trim. I removed enough nose weight to eliminate the up trim, and I'm guessing the balance point is now on the back side of the main spar.
I found the glide ratio to be astounding for an 11-ounce sailplane. The longest hand-launch I achieved was over 350 feet when the wind was almost calm. With just a gentle shove, I was able to get 15-20 feet of altitude. All hand launches were at least 200 feet or so. I think that with a little practice, hand launches to an altitude of 50 feet or more will be achievable.
Given that I may be little rusty, I'm waiting for a very calm day before trying a high start launch.
He then followed up with:
I've been able to test high start launches (first time I've flown in 45 years), and she goes up like a rocket with very minimal and evenly distributed wing flex. Remember, I added vertical grain balsa sheer webbing from the root to midway in the outer panels (I'll explain my exact build at the bottom of this message). My high start uses 10 meters of 6mm OD - 3mm ID latex rubber tubing I purchased from Amazon. I added 100 feet of braided fishing line and a flag. I used four pounds of high start tension (about 2.5X my bungee length and 5X my GL weight) and my GL consistently reached a launch height of at least 125-130 feet with some tension remaining at release. I've got a video that I can send if you like. It's a super fun setup that you can quickly launch over and over.
I felt my CG was getting a little too far rearward and figured out the problem - too much tip washout. I've got to get rid of my old-school conventional wisdom. Everything I flew in the '70's required tip washout and had flat bottom airfoils. The GL's 55" wingspan combined with its airfoil make tip stalls very unlikely. I'm going to remove all the washout and test again tomorrow. My glide ratio will definitely go up, and I bet she turns just as well.
I definitely added weight to beef up the airframe for high start launches. I might have gone too far, but the airframe handles high start launches with no problems at all, and she still feels light and flies like she's on rails. I really love my GL-EVO. It's the perfect quick flyer. Thanks again for all your help. I'm really glad to do business with you!
