Gentle Lady EVO
Dryheat
User
Motor mount melted. First flight of the day and only three minutes. Flat ground and 10mph wind 80ish. I was very close to me and holding steady into the wind. No forward movement. About 50% power and boom the motor came out. Hanging by wires only. I landed in alfalfa without damage. Fixable but dang!
Is that the smaller prop? You are on 2S battery?
We had another report of this a while back and have switched out the material we are making the firewall and spinners from. We also added some additional cooling holes in the spinners.
We can send you the new parts for free, the bad news is it will be difficult to fit the new motor mount into a built plane.
I am confused why you still have two screws in the motor mount. Did the screws become unsecured, and this allowed the spinner to rub the fuselage? Looks like it rubbed through the covering on the bottom of the fuselage? Just guessing at a possibility.
Happy to send you the parts for a new fuselage too, but I think with some careful fremel work to remove the old one you can slide the new one in, less work than building a new fuselage.
The new motor mount and spinners will handle temps high enough where the motor is damaging its own magnets.
We had no issues with heating during our testing, so sort of surprising to see two examples of this now. Before we went to production we had several kits built and tested by beta testers. Things always pop up, just shocked to see this coming up. Not what we want to see happening for sure.
Let us know what we can do to make this right.
To me it looks like the motor mount got warm enough to soften. this would allow the screws to back out as the tension holding would have changed. With the top one loosening first that would allow the spinner to touch the fuse.
@Dryheat were you running the motor the whole time?
Just my thoughts
Hank
You sure are right about two screws left in the mount. Clearly they came unscrewed. The spinner was dragging on the fuselage! You can see the lip the dragging created. The prop 2” and yes 2s 7.4volt 650mha. The good news is my buddy wants this plane as a display in his barber shop. I see you have the kit back in stock so i will order a new one and build it lighter and gooder and prettier. Mike
Just my thoughts
Hank
See my reply to Wayne as this was my fault. Loose screws.
Nope - You are getting a free kit! (If you ordered, let me know the order number and I'll sort it out.)
I think Hanks thoughts seem credible.
Ok, just so we’re clear I didn’t mean to bash this kit. It’s awesome. DM sent.
If anyone here has already purchased this kit but hasn't assembled it yet, please send me a DM! I'll be happy to send you the updated parts (motor mount) free of charge!
Motor mount are now made with new, improved filaments that are safer, stronger, and more resistant to higher temperatures.
If anyone here has already purchased this kit but hasn't assembled it yet, please send me a DM! I'll be happy to send you the updated parts (motor mount and spinner) free of charge!
Both parts are now made with new, improved filaments that are safer, stronger, and more resistant to higher temperatures.
I assume these parts are in the kit i ordered today.
FWIW this also happened to me with a very similar motor mount sold by another company.
In that case the excess heat was likely caused by user aggressiveness. I was flying on a 3s 550mah pack. After enough full power climbs the motor heated up a lot and the screws backed out.
I dropped to a 3s 300mah (about 4 min of motor time which is plenty) and never had an issue again.
The surprising thing here is it doesn’t sound like @Dryheat was flying aggressively like I was.
When we went to Los Banos, it was pretty hot and I was flying one of the production GLE and I started off with minimal use of the motor, but kept using more and more throttle to see if heat accumulation was an issue in flight. Ran a couple of battery packs through her over the weekend. We had the old motor mount and spinner on this plane. I had no issues at all.
I'm wondering if there was some rubbing of the spinner to the fuselage, and that extra friction was enough to make the extra heat? Or maybe it was just the result of static running it for a period of time? I generally do not static run any of my electrics for very long. In flight they get a lot more cooling.
@Wayne when OP talked about the plane having no forward movement, that was relative to the ground, I imagine. I assume the plane was still flying into a headwind, so there should have been plenty of air cooling (and I assume the plane was NOT hovering, as that would mean no windspeed either).
We can send you one. What color?
We made up a small batch for the initial kits as a bonus. We all hate picking the stickers.
