Frsky twin x lite s gimbal
Sure, check the manual (can download from FrSky) but there are some screws for adjusting the tension.
Thanks for the info . Right out of the box the external bay has no power .. Hopefully FrSky will exchange it as I've only had it since the 23rd . And they are closed till the first
Allen
Did you put something into the extrenal bay and then tell the radio you have something in there? Not sure on the X-lite, but some of the radios need to be told there is something there to send power too. Others always have power.
Yes , I put a twin module , irange , r9 ..I put a elrs module in it and applied external power to the module and it works fine ..voltage on the external pin is 3.45 to 6.1 ..it fluctuates ....
Probably a bad power board . The battery connector and external module pins are all on the same board . It also has the voltage on the pins whether the radio is off or on .
Thanks
Allen
